pressure vessel boxes
Can anyone refer me to what codes refer to the design (wall thickness in paticular) of a pressurized rectangular box. I have been told that Section 8 div 1 deels only with cylindrical or spherical vessels.
RE: pressure vessel boxes
Also since i prefer not to spend the money can anyone refer me to an alternate way of calculating what i need? i have found plenty of stuff in calculating cylindrical object but nothing for thickness of a box.
However, before constructing any sort of pressure vessel, you should determine if a Coded vessel is required for liability, contractural or other reasons.
Mike
SOLUTIONS 1
Google search for
Non-Circular Pressure Vessels-Some guildance notes for designers M. Starczwksi B.Sc. Eng. Stress Engineer, Research Dept, British Enginer Technical report 1981 Volume XIV.
http://www.gowelding.com/pv/square.pdf
SOLUTIONS 2
SOLUTIONS TO DESIGN OF WELDMENTS
The James E. Lincoln Arc Welding Foundation, Cleveland, Ohio
Been their did that
Leonard Stephen Thill
htt
As far as we are aware it is the only code that covers rectangular vessels.
