Temperature effect over hydraulic turbine
Assuming an hydraulic turbine of an hidro electric plant. Is it correct to assume that the water temperature at the outlet of the turbine can be calculated  from the balance:
enthalpy of water at outlet = (enthalpy of water at inlet) minus (shaft power hydraulic turbine)?
fuentes 303
RE: Temperature effect over hydraulic turbine
enthalpy is in kJ/kg
temperature is in degC
you don't quantify cows by counting sheep
