Nastran Punch Files for Stiffness Matrix
I am would like to know how can I get the stiffness matrix at some specific nodes of a Nastran Finite Element Model?
I believe that I should prepare a punch file with contents similar to the following lines:
DMIG    KAAX           0       6       2   0                 363
DMIG*   KAAX                     815               1
*                815              1 2.094630203D+05
DMIG*   KAAX                     815               2
*                815               1 5.452199544D+01
*                815               2 7.202035606D+04
DMIG*   KAAX                     815               3
*                815               1-1.187792338D+04
*                815               2-8.340854301D+01
*                815               3 7.054812146D+03
DMIG*   KAAX                     815               4
*                815               1 5.956672400D+03
*                815               2 1.614047795D+06
*                815               3-9.830448080D+03
*                815               4 8.008238936D+07
DMIG*   KAAX                     815               5
*                815               1-3.302141465D+06
*                815               2 4.679375985D+03
*                815               3-6.878970667D+05
*                815               4 6.516078489D+05
*                815               5 2.395260092D+08
DMIG*   KAAX                     815               6
*                815               1 2.197964123D+03
*                815               2 9.450145395D+05
*                815               3-5.384814661D+03
*                815               4 4.320186476D+07
*                815               5 4.148338821D+05
*                815               6 2.530261259D+08
A.A.Y.
RE: Nastran Punch Files for Stiffness Matrix
Hello feajob,
            what you should do is run a file where the GRIDs for which you require the stiffness values are defined via the ASET card:
ASET1     123456   GRID1   GRID2    ...   GRIDn
and add in the parameter section of the same file the line
PARAM,EXTOUT,DMIGPCH
It should give what you are asking for.
Spirit
'Ability is 10% inspiration and 90% perspiration.'
Hi Spirit,
Thank you for your response. I put the following lines in a model.
aset1,123,3245
And, I got a punch file as follows:
DMIG    KAAX           0       6       2       0                  155520
DMIG*   KAAX                        3245               1
*                   3245               1 1.169233642D+02
DMIG*   KAAX                        3245               2
*                   3245               1-5.191796938D+00
*                   3245               2 1.489866977D+02
DMIG*   KAAX                        3245               3
*                   3245               1 4.308966685D+01
*                   3245               2 6.827149784D+00
*                   3245               3 2.929045851D+02
DMIG    PAX            0       9       2       0                       4
DMIG*   PAX                            1               0
*                   3245               1 8.973292961D-01
*                   3245               2-2.682531133D-02
*                   3245               3-2.384527642D-01
DMIG*   PAX                            2               0
*                   3245               1 8.254319696D-01
*                   3245               2-2.436249156D-02
*                   3245               3-2.537991949D-01
DMIG*   PAX                            3               0
*                   3245               1 8.194554349D-01
*                   3245               2-2.450994401D-02
*                   3245               3-2.631562907D-01
DMIG*   PAX                            4               0
*                   3245               1 4.426057545D-01
*                   3245               2-3.810084949D-02
*                   3245               3-2.589523757D-01
DMIG    VAX            0       9       2       0                       1
DMIG*   VAX                            1               0
*                   3245               1 1.000000000D+00
*                   3245               2 1.000000000D+00
*                   3245               3 1.000000000D+00
Actually, I was looking only for KAAX. Please let me know if you know anything about PAX and VAX. I guess that PAX is related to load matrix, but I don't know any thing about VAX.
A.A.Y.
Hello feajob,
             the PAX matrix indeed refers to the reduced matrix of loads. I don't know the exact meaning of the VAX part, I read somewhere that it should be related to the rigid mody motion of your model (not sure though).
I usually erase it happily from my reduced structures files anyway.
Spirit
