Required source
Required source
For the last couple of weeks, at the same time everyday I get a message that states "required source" and then shuts down solidworks. Why is it all of sudden doing this, what is it looking for. It seems to be when we are saving files, the files are on the network, but no one else is having this issue at our company.
RE: Required source
Shut down as many apps as you can and/or apps (processes) running in the background and see if that helps.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
RE: Required source
Chris
SolidWorks 09 SP4.1
ctopher's home
SolidWorks Legion
RE: Required source
What Version of SW are you using? I don't Care what video card is any of them can run SW in software open GL. Do you have multiple versions of SW on machine?
To get more detail on error if you haven't already Run "eventvwr" from Run command and look at Application or System errors. When I installed 2010 on my machine I got the following error when launching program. Your error may be reelated to the Source missing in Shortcut. This information is recorded when using SolidWorks RX to capture problems and may give more information that you'll find useful or that your VAR will.
Event Type: Error
Event Source: SolidWorks SC
Event Category: None
Event ID: 101
Date: 11/11/2009
Time: 2:53:34 PM
User: N/A
Computer:
Description:
The description for Event ID ( 101 ) in Source ( SolidWorks SC ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event: 98-171.
Michael
RE: Required source
RE: Required source
Matt Lorono
Lorono's SolidWorks Resources & SolidWorks Legion
