Pipeline Education
Pipeline Education
I am looking for a good source to learn the ins and outs of pipeline (water, storm, sanitary) design and construction techniques including what types of piping is available and what are the best uses of each, types of fittings, construction methods, etc. I know this is a broad topic.
RE: Pipeline Education
David
Then there are your country's standards, AWWA standards and bookshop. These will be referenced in the above manufacturers' literature.
Dan
www.eltronresearch.com
Dan's Blog
http://140.194.76.129/publications/eng-manuals/
EM 1110-2-503 Design of Small Water Systems
EM 1110-2-501 Small Wastewater Systems
EM 1110-2-2902 Conduits, Culverts and Pipes
As you develop specific questions, I think with the use of a few key words you will find a great deal of information is available from many references, and maybe even quickly on Engineering forums and lists that have existed for many years (like this, use the "Advanced Search" feature).
As with any reference (and some might argue particularly free information from the Web!), it is likely not all information will be solid, but I believe a lively discussion of many folks (and some I believe who have a great deal of experience) sometimes on quite lengthy threads and maybe even a little application of ones own logic has a tendency to somewhat separate the good from the bad, and facts from opinions or not necessarily substantiated theory .
San Diago area water utility association.
Lots of information about most things you'll need with standard drawings too.
http://www.sdwas.com/index1.htm
"The problem isn't working out the equation,
its finding the answer to the real question." BigInch
http://virtualpipeline.spaces.live.com/
