Microsoft Outlook .cfg file
I am on V20 and every time I save an assembly file it creates a .cfg file that XP says is a microsoft office outlook file. Is there any way to turn that off so it does not always create this file?
RE: Microsoft Outlook .cfg file
This file is the configuration file for the Solid Edge assembly.
t will always be there.
You can delete, but SE will create a new one. There is no need to open or view this file. Learn to ignore it.
This is the file that holds all the assembly configuration information.(I'm not sure if it's just display configs)
If you save different configs the info will be stored here.
If you then delete it all those configs will be lost.
The reason its being shown as a Microsoft Outlook file is because that's how Windows is set to recognise the .cfg file extension.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
Very usefull indeed if you have the need for it.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
