UCS 65 Lowest Impact Test Temperature
3
Code: ASME VIII Div I
Will I be correct in saying the lowest impact test temperature I can subject A516 Gr70 plate to is -105 degC?
Thanks in advance.
RE: UCS 65 Lowest Impact Test Temperature
UG-84(b)(2) indicates that the test temperature must not be higher than the MDMT, therefore they do not indicate at what temperture a test is to be performed as long as the impact energy is satisfied in Fig. UG-84.1.
As an example discussed by K.R. Rao in the Companion guide (viewable in goggle books) pg 74.  Example: MDMT is 30F and the vessel is subject to a decrease in temperature due to the stress ratio of 100F, therefore the allowable operating temp is -70F, but this is below the mandatory impact test temp. of -55F. So impact testing is required, but only at 30F, and the vessel is safe for -70F.  (This was clarified in Intrepretation: V111-1-89-268).
SA 516 Gr.70 plates would not impact tested to this low temperature. Vessel having MDMT of -105 Deg C will not be of SA 516 Gr 70 plate.
Have a look at SA-20 which gives generally available thickness and minimum test temperature combinations meeting charpy V- notch impact requirements.
No, this statement makes no sense because you have no mention of MDMT and thickness. Go back and review UCS-66.
Metengr,
Assume MDMT -105 degC.
Bushan76,
I know this is extreme cold temperature, but the question is, can 516, 70 be used or allowed for this purpose subjected to acceptance of impact test.
Thanks in advance.
Sure, if it can pass the impact test (which it won't).
