Fire Damage to Ductile Iron Pipe
Has anyone heard of delaminating of the cement lining on DI pipe as a result of fire damage?
Fire Damage to Ductile Iron PipeFire Damage to Ductile Iron Pipe(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Fire Damage to Ductile Iron Pipe
I believe virtually any substance or piping material can be affected with sufficient application of heat!
Ductile iron piping is FM listed only for underground fire services. Exposed ductile iron piping will not handle the pipe stress caused by the temperature difference in a fire. The gaskets will fail at 300 Degrees C. The fittings will fail because of the pipe stress caused by the temperature.
Ductile iron has a relatively low melting point of 2100 Deg F. Steel has a melting point of 2700 Deg F. A fire flashover occurs at about 1000 Deg F.
Richard A. Cornelius, P.E.
WWW.amlinereast.com
Ductile iron pipes, and gray cast iron pressure pipes furnished before them in the USA and up until the late 1970's, are in a sense literally born of heat and fire, and I guess I was somewhat surprised to see much singling out concern of heat on the piping material per se (after all, iron has long been a traditional material e.g used for wood-burning stoves and frying pans etc.!) While I have only been in the industry for 35 years, I was likewise also not aware that there was promotion at least in any recent era in the USA of cementlined ductile iron pipes specifically for "steam service" (though I guess I would also not necessarily surprised if it is being used somewhere). I am aware however that for many decades ductile iron has however been rather exclusively specified for some specific and otherwise potentially problematic scum etc. lines e.g. in wastewater treatment plants, that might be subject to "steam cleaning" (should that ever be necessary in the future to remove clogs), although I think instead of cement mortar lining many of these quite special lines have been and are specified with special glasslining, that reportedly has greater lubricity than any common plastics or polymeric linings, and adequately chosen temperature gaskets. Contrary it would appear to perhaps some inference of this thread, ductile iron is rather exclusively specified for such services, due to its proven performance and its tolerance for heat, to allow for the extremely high temperature firing of the glasslining on the inner pipe wall, and also effects of potential future steam cleaning.
I think Mr. Cornelius has made a good suggestion, i.e. to take look at the linings etc. by whatever means available and see what they actually look like after the event. If this is a water pipeline instead of pipe stacked in some sort of storage structure, perhaps it may also be possible/make sense to look at any other components as well, and maybe even run a new hydrostatic test at greater than working pressure to get a better feel also for present gasket/joint integrity. If all else is OK, perhaps any damaged gaskets might be readily replaced with some common joints of exposed ductile iron piping ?
Now, all this being said, if you choose to not coninue to utilize the piping for whatever reason, I suspect it might
well (unlike many other types of pipe, or other relics of fires) still bring top dollar from even your local scrap dealer.
This was referring to underground piping located adjacent to steam piping and experiencing the heat from adjacent steam piping.
Some additional reports and references:
http://n
http://www.dipra.org/pdf/cementMortarLinings.pdf
I am aware of the conservative service temperature document of DIPRA, but I was unable to open whatever the other document (as you say apparently some issue or concern of proximity of piping to hgih temperature steam lines?)is. Do you have another link (e.g. to html etc.), or could you at least provide the copy of the paper etc.? [I do understand some at least concern in general on the part of authorities, as I do remember a very problematic burst of a sizeable pvc waterline in proximity to a steam line in the Midwest several years ago.]
Condition Assessment of Ferrous Water
Transmission and Distribution Systems
STATE OF TECHNOLOGY REVIEW REPORT
EPA/600/R-09/055 | June 2009 | www.epa.gov/ord
Office of Research and Development
National Risk Management Research Laboratory - Water Supply and Water Resources Division
[I was able to go to site at link you provided, then readily access the paper with a keyword search -- I guess problem could be my caveman computer! In quick scan I could not find however a specific citation re steam, but will look in more detail when I get a chance.]
