ISO / DIN specs
ISO / DIN specs
i'm trying to develop a CAD library of metric "mil spec" hardware. I've found out that there isn't a mil spec for metric hardware...SHCS, FHCS, washers, nuts, hex bolts etc.is there a spec for this type of application, either ISO or DIN and where can i find such. the specs that i've found are broken down into categories w/ numbering nomenclature and i don't know what i'm looking at or what to search for. i have to build the CAD libraries and i don't know what to name the models so that they show up correctly on our BOM's. can any point me in the right direction?
TIA
TIA
Sr. Pro/E Mechnaical Designer
RE: ISO / DIN specs
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
