high value resistors on thin film ceramic
Is it possible to fabricate a > 1 gigohm resistor on a thin-film ceramic layer? I'm not talking thin-film resistors, but a resistor layer on a thin-film carrier (PCB). Or would I want to do it on a different type of layer, as the resistive layers typically are fairly low resistivity (100 ohm/sq). I thought I'd post a general question here before getting into specifics with the various ceramic vendors.
John D
John D
RE: high value resistors on thin film ceramic
I would concentrate on that aspect...break it up into many discrete resistors in series, maybe 50 Mohm each, and machine away board material in between the resistors. Good luck.
www.MaguffinMicrowave.com
Maguffin Microwave wireless design consulting
Beware of spiral cut or similar resistors if the application is RF (this being the Microwave etc. forum...).
If this isn't a pH meter application or someting similar, I can not think of any application where this level of resistance is needed. And I know that such resistors are not used even in pH circuits. Or, at least, that such circuits can be built without such extreme resistors. Nanoamperes require teflon insulators - how can you get even close to that on a ceramic substrate?
I think that you need to rethink that spec.
Gunnar Englund
www.gke.org
John D
