Inventor Library - Desscription Issues
Our Inventor package came with a library for copper tubing and fittings. The library uses standard nominal size descriptions in the generated BOM but we use ACR descriptions, that is, instead of calling out 2" nom tube (actually 2.125" OD), in ACR it is called out as 2 1/8" nom. tube. Is there any way to modify the library so the descriptions use ACR nominal sizes in the BOM's?
