Install v6.9 on Windows7, 64-bit
I am getting an error installing Abaqus 6.9 on my new laptop. It uses Windows 7 Ultimate with 64-bit OS. When I try to install the program (the documentation go on OK) I get:
WARNING: Unexpected output from Abaqus executable findWinVer.exe.
ERROR: This computer's platform is Windows/x86-32 but the Abaqus release was
built for Windows/x86-64. Please install and execute the Abaqus release
built for Windows/x86-32 to ensure compatibility between your system and
Abaqus software.
Abaqus sysinfo execution exited with error(s).
Abaqus sysinfo failed.
It looks like from the WARNING message that the findWinVer program does not pick up the correct version of the Operating System. Anyone else seen this and have a work around?
Abaqus software.
RE: Install v6.9 on Windows7, 64-bit
ht
It seems that Windows 7 is listed as supported only for v6.9EF, but not for v6.9 , but probably you should check this aspect with the Abaqus Support.
D:\setup -nosystemchecks
to install the program.
