van der waals problem
hello i am new at this and i cant solve van der waals equation
on mathcad
i tried    R:=0.0821  Latm\mol K
P:=1,2...3 atm  T:=283,287...333 K   a:=3.59 b:=0.0427
and write the equation
    f(V):=[(P+(a/V^2))*(V-b)]-[R*T]
now what should i do to get volume values from this equation
i tried everything i couldnt find some examples similar
plz help on it
thanks for helps
RE: van der waals problem
What do you mean "get volume"  You've defined a function whose input is volume, which makes it an unknown.  Unless you have values for the function, you have two unknowns and one equation.
TTFN
i see, it s my fault
ihave pressure, temparature ,R ,a,b
i defined all i have 3 diffent pressure value
and 10 diffrent temp value (it means 30 diffrent volume values)i want to find them with van der waals
if i had have volume values i could easly found temperature
or pressure parameters but when volume is variable , it
is more complex
i think it can be solved by given-root
but i don know how
the equation is
    [P+(a/v^2)]*(V-b)=R*T
  i need to find volume by use this
  sorry about my poor english
The given-solve functionality is well documented in the help files.  The only adder you need to do is to assign the find(V) to a function whose inputs are P and T, i.e.,
Given
  [P+(a/v^2)]*(V-b)<CTRL>=R*T
func(P,T):find(V)
i:1;10  j:1;3
func(Pj,Ti)=
TTFN
it not works
 says func isnt defined
Did you even read the help files?
You need to supply a guess value for V.  You futher compound whatever other problems you might have by not using units, but also using V, which is a built-in unit designating volts.
TTFN
perfect thanks for help
i have no idea about vectors and matrises on mathcad
but it will help me to understand
and problem is solved
thanks and thanks again
thanks this sheet is very helpful to me
