Dong/Battelle hot spot metod
Hi, i'm dealing a fatigue analysis to a welded joint and i'm trying to implement the Dong/Battelle procedure to gain the hot spot stress.
The problem is that i can't obtain the right values (i'm comparing my procedure to other results present in literature).
someone has already faced the problem?
I think that is a problem of value averaging at the nodes (for nodal forces and moments), but I haven't still exceeded it.
do you have any good advices?
many thanks!
many thanks!
RE: Dong/Battelle hot spot metod
i'm working on a simple example of a plate lap fillet weld that join two plate, and the model is made by shell 4 nodes element.
any help will be very apreciate. thanks
