Bind an Image into a DWG
Is there any way to bind a raster image into a drawing similar to binding a *.dwg XREF?  I don't want to have to keep the *.gp4 and *.tif files along with the *.dwg file.  Bind isn't a selectable option when you right-click on the raster image reference.  It is if the XREF is a *.dwg file.
RE: Bind an Image into a DWG
The main problem with an image as part of the drawing is the increased size of the drawing.
