Structual Magnatisum
I'm a welder that is working on structual steel replacement in a mining refinery. I'm having a hard time with magnatisum that isn't present untill the column is cut. Its so strong that it will hold a 24" pipe wrench. I've heard different oppinions towards DC and AC. I'm wrapping the column with the ground and using Electrical bonding cables but nothing is working. The magnatisum is to strong. Any ideas on how to weld with this.
RE: Structual Magnatisum
h
#09180019 should work, and is not terribly expensive.
