collapse pressure of ellipticle domes
I am thinking of using ASME 2:1 elliptical tank heads for the construction of an electronics enclosure which will be submerged to a maximum depth of 1000M. I am seeking a source for the calculation of the yield point from positive pressure applied to the convex side of the head.
Ant help will be appreciated.
RE: collapse pressure of ellipticle domes
ASME Section VIII-I covers external pressure as well as internal.
I would also endorse the ASME Section VIII, Division 1 calculations.  The failure mode of the 2:1 semi-elliptical heads is not yielding, as you might expect.  Especially under external pressure (which appears to be your situation), buckling is going to be a primary failure mode.
Can you use hemispherical heads?
This is sort of the standard when going to these depths.
Another approach I've seen used is the reversed head but I don't know the depths it was used at.
I will make a spreadsheet for the hemispherical head, the elliptical dimensions made it my first choice. Thanks to all for the replies.
