Dashed/Dotted lines in a drawing
I just want to do a quick drawing using the drawing feature in SolidWorks.  No need to build parts yet.  I was just wondering if it is possible to change some of the lines to dashed or dotted lines?  Any info on how to do this would be greatly appreciated.  Thanks.
RE: Dashed/Dotted lines in a drawing
Enable your Line Format toolbar and/or check the "For Construction" box after you highlight a sketch segment.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
You can also try layers. Set new layers, assign style and thickness. Apply as you go.
~ BT
Awesome, Thanks a bunch for the help guys. This forum rules.
try, play around with the dim style, change font/color
~ BT
