Line style settings for 2D Exchange
When I export an NX6 drawing to DWG using 2D Exchange the hidden lines don't show up as hidden when opened in Autocad.
Their set as gray & hidden in the UG drawing. The gray comes through & the line style name is "Dashed" in Autocad but appears solid.
Is there away to change my export settings for this?
James
James
RE: Line style settings for 2D Exchange
It may help to turn the line width on in the drawing
Preferences > Visualization > Line > Show widths (toggle on)
Does anyone else have any ideas on how to get hidden lines to exported better?
Is it possible to change this setting in my "ugto2d.def" file?
James
To control and optimize choose the 2d output to Nx partfile.
Open this flatt nx file and optimize the dxfdwg process to your nned maybe with a mapping file -> look into the data echachange docs of the NX Documentation
Thanks guys for your advice. I've tried your suggestions but it didn't seem to have any affect.
Is anybody out there able to create a DWG file using 2D exchange (output to Modeling) which has the correct hidden line style visible when opened in Acad?
Your responses would really be appreciated!
James
