NX5 Dimension Disappears from Drawing
The drawing file I am using will not allow me to add dimensions to a view. I can pick the features, the dimension will show and when I pick the location to place the dimension, it disappears. When I go into EDIT > UNDO, it shows that a dimension was created, but I cannot find it. Another problem in the same file, I try and add a note to the drawing, but it also disappears. I must have toggled something off because I was creating dimensions earlier, but I can't figure it out.
RE: NX5 Dimension Disappears from Drawing
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
File > utilities > part clean-up
These little issues can be very frustrating!
I'll try your tip as well to maintain my file. Thanks for the response.
You should do a part clean-up every once in a while to get rid of unwanted things in your part file. Once a day would be a good habit to get into.
