ADI for 4 link
ADI for 4 link
We are looking for an alternative to standard DOM tubing for a 4 link. And I was curious if anyone had any success with ADI for suspension systems? I've done a lot of research and I can only find an article on when Ford used for the 99 Mustang as well as some older info on rear ends. But nothing new.
If you have perhaps you can answer some items I am unsure about. Mainly I am concerned with the ductility of the material. Normally we would use a DOM tubing, which in itself is light weight, strong, tuff and ductile (elongation before break (15-20%). As well there is a substantial difference between the yield and tensile, which is sort of a rough indicator of the toughness.
While adi has 110 tensile, 75 yield and an elongation of 11%. As well the reduction of error is low around 10%. Based on these numbers it would not be as tough or ductile. But further research has shown this not to be the case. As impact and fracture strength are quite high.
The reason for the change is purely cosmetic, we need something nicer than a simple tube.
RE: ADI for 4 link
RE: ADI for 4 link
I was involved in the design and development of a complete front end suspension made from aluminium, it is certainly possible, and in fact has given us no problems so far. It's been in the market for 4 years now. I think BMW uses a lot of aluminium in their suspensions as well.
Cheers
Greg Locock
RE: ADI for 4 link
Greg, I would definitely like to do something in aluminum but I don't have the resources or experience with the material.
RE: ADI for 4 link
Guessing that is your spellchecker gone mad, what did you mean to type?
Cheers
Greg Locock
RE: ADI for 4 link
RE: ADI for 4 link
seems to have a lot of useful data.
Cheers
Greg Locock
