Coking Barrier Fluid
I have an application where an API plan 54 is used. A recent failure had heavy coke build-up on the atmosheric side of the mechanical seal. The barrier fluid is Synturian Six at 100psig and 4gpm. The process is heavy gas oil at 700 degF. The first thing that pops in my head is...The plan 54 circulator was not operating properly. The seal support system is under further evaluation. I have two questions...
1.) At what temperature does barrier fluid coking on the atmospheric side of the seal become a concern?
2.) Can coking on the atmospheric side of the seal create a slip-stick condition that could potentially crack a face when the pump is started?
RE: Coking Barrier Fluid
trust this helps
