Energy meter with fast cycling load
I have on my bench a kWh meter that is supposed to have a systematic (all meters of that type seem to have the problem) error.
Calibration works out fine, but when you cycle the load with a few seconds on and a few seconds off, the meter registers more energy than is actually used by the load.
The reason this deviation was detected is that a guy with a (I think) badly designed thermostat in an around 2 kW application thought he paid too much for electricity. Utility did a check and found that the meter actually registered too much energy. Not when testing with steady load, but when checking with parallel meter from other manufacturer.
I have some theories about this. But feel genuinly unsure. My first thought is that some accumulating or filtering software is asymmetrical so that 'attack' is faster than 'decay' - if I am allowed to use musical language.
Anyone has any experience with this? Heard about a similar thing? I am open for all possibilities - the weirder the better (well, within limits).
Gunnar Englund
www.gke.org
RE: Energy meter with fast cycling load
Did you hear about the retired railway man with the sleep disorder? He would wake at random times for a few hours and go back to sleep to wake again at a truly random time. When he awoke he would go down to the tracks and wait for the next train to pass. He would note the direction of the train and return home to sleep again. He saw three times as many east bound trains as west bound trains. How could this be? Actually there were the same number of trains each way, but the eastbound train passed on the hour and the west bound train passed 15 minutes later.
He had a 15 minute window of opportunity to see a west bound train and a 45 minute window of opportunity to see an east bound train.
Random sampling produced a 300% error.
Is it possible to have a similar interaction between the sampling rate and the load cycling rate?
Bill
"Why not the best?"
Jimmy Carter
If the sampling is spread over all six channels, then anything could happen, 3.33 Sa/period and switching load on/of in seconds could produce some interesting interference patterns. But ought to equal out in the long run. Also, this is a well-known manufacturer and the specs (checked by independent lab) are good. So, I think we have 20 Sa/period on each channel.
I am setting up a test with triacs for fast cycling and a bank of 9 times 300 W lamps. It is getting bright (and hot) when we turn them on.
Gunnar Englund
www.gke.org
Bill
"Why not the best?"
Jimmy Carter
Gunnar Englund
www.gke.org
Keith Cress
Gunnar Englund
www.gke.org
The length of this packet is 8 seconds (Delta C3-C2) and the off time is 7 seconds (Delta C2-C1).
Not much distortion.
Gunnar Englund
www.gke.org
Keith Cress
But interesting to see the waveforms do not go to zero during the off-time. Is there maybe measured energy accumulating during the off-time?
First, yes, this is what the customer's load looks like. It is an ordinary one-family house at around ten o'clock in the morning. There are very few other loads except the heater that is connected between L2 and L3. When the heater is on, current flows from L2 to L3, so channel 3 and 5 shall be 180 degrees apart.
Then, when the heavy load is off, there is something with o little crest. Probably a switchmode power supply (TV set or computer) in channel 3.
Channel 1 was off in the upper picture, but is activated in lower picture. Looks like a modest linear load. It was mentioned that a small heater with a fan was on in addition to the heater.
There seems to be a DC offset in channel 5 lower picture. I hadn't noticed that before. Me to wonder from where that comes. Shall look for it in my following recordings.
I am now trying to load the meter with a set of incandescent lamps controlled by a three-phase thyristor bridge that is, in its turn. controlled by a function generator so I can have rapid cycling and really nasty waveforms. Trying to provoke bad behaviour.
My first test will be to check if there really is a fast 'attack' and a slow 'release' when power is cycled. If there is a linear filter involved, I think that cycling should have no effect on the accumulated energy. If the filter behaves differently when switching power on and switching it off, I think that there could be a net error.
Thanks again. Six eyes are a lot better than two.
Gunnar Englund
www.gke.org
Keith Cress
These meters are made in millions, so I guess that there's a lot of application specific stuff inside.
Good thing: Got my thyristors working, really nasty waveforms and cycling at several Hz. My lab has turned to a disco.
Now I have a 'slight' Excel problem; how to measure distance between the metering pulses. Each pulse is around 60 rows in the sheet. I have done edge detection and have a resulting '1' for each positive edge. Now looking for a way to measure distance (seconds) between the edges. Never done that before. Guess I can use row number when I find a cell with '1' in it and subtract row number of previous cell with a '1'. Not what I usually do.
Gunnar Englund
www.gke.org
I don't work with meters, but the whole thing is mysterious to me. I would have thought a kw-hr meter would simply accumulate continuously using simple stepwise integration of instantenous power (V*I) to get energy W:
Wk+1 = Wk + (Ik+1 * Vk+1)*DeltaT .... where DeltaT is time between samples.
Apparently it is different than that because there is something called a "metering pulse". What is the purpose of a metering pulse? ... When pulse occur the power is computed (based on a half cycle or cycle interval), and used as representative of the entire interval between pulses?
In either case, I'm not sure what would be the purpose of a filter. I guess I can see the 2nd algorithm (metering pulse) where we look at a short shapshot 1-cycle or so would be susceptible to small deviations in power frequency... if the samples do not occur at exactly submultiples of power frequency period than a snapshot 10 or 20 samples would have some error based on looking at an interval slightly different than a full or half cycle.... and it power frequency was consistently different in same direction that error would not be random. Might need something more complicated to deal with that which I suppose could include a filter. But nothing here to do with cycling loads.
Do you know yet the approximate time between pulses?
What is the magnitude of the error that is seen?
Metering pulses are short (20 - 40 ms) pulses that corresond to a certain amount of energy. In this case 1000 pulses correspond to 1 kWh. Distance between pulses can be seen from attached recording. It is from the same measurement as the ones shown before. But this is taken over longer time. The metering pulses are on channel 6 (blue). Currents in the three phases are shown in channels 1, 3 and 5 as before.
Gunnar Englund
www.gke.org
The viewer program is available at http://www.gke.org/test/ and I will put the original file on http://www.gke.org/pub for download. Data files with faster cycling will also be uploaded soon.
Gunnar Englund
www.gke.org
= FindOne(3,A1:A5,False) would find the 3rd occurence of the number 1 from the bottom in range A1:A5
CODE
' Finds the Occurence_th occurence of the number 1 within range,
' (For example if Occurence = 1, it finds the first occurence, if Occurence=2, if finds 2nd)
' it searches downwards from top if SearchDown is true
' it searches upwards from bototm if SearchDown is false
' Note you can use the built-in match function if you simply want to search down for first occurence
' Assumes the input range is a single-column range... no error checking is done
Dim rowcounter As Integer ' count rows of range
Dim foundcounter As Integer ' count number of 1's found
Dim thisrow As Integer ' identifies row number for the loop
Dim thiscell As Range ' identifies cell for the loop
FindOne = 0 ' Error flag - if function returns 0 there are not enough 1's in the range
foundcounter = 0 ' Initialize
For rowcounter = 0 To myrange.Rows.Count - 1
' Set thisrow according to User Preference in SearchDown
If SearchDown = True Then
thisrow = rowcounter
Else
thisrow = myrange.Rows.Count - rowcounter
End If
' Identify the cell of interest
Set thiscell = myrange.Offset(thisrow, 0).Resize(1, 1)
' Increment foundcounter if cell contains 1
If thiscell.Value = 1 Then
foundcounter = foundcounter + 1
End If
' If foundcounter matches target, output results and terminate
If foundcounter = Occurence Then
FindOne = thiscell.Row
Exit For
End If
Next rowcounter
End Function
I had a feeling you would jump in and help. Much appreciated. Only, I have never done user defined functions. Something new to learn!
Gunnar Englund
www.gke.org
Here's how to use the function (at least in my excel 2003)
In the workbook of interest:
Select Tools / Macro / VisualBasicEditor
Select Insert / Module
That should open a subwindow which says "General" near the top.
Paste the entire code listed in my post above into that subwindow
Perhaps double check on left side that the selected module (module 1 probably) is in a folder named modules which appears underneath something called 'VBA Project ("MyFile.xls")'.... where MyFile.xls is the name of your spreadsheet. This just verifies you are working in the right place, rather than inserting into your personal.xls or some other vba window.
Select File/CloseAndReturnToMicrosoftExcel
"thisrow = myrange.Rows.Count - rowcounter"
needs to be changed to
"thisrow = myrange.Rows.Count - rowcounter - 1"
Attached is a spreadsheet I used to test the corrected function. Sorry for the error.
So let's say during that busy period after reaching to limit trigger, the microprocessor is in fact busy... so busy that it cannot continue to monitor the incoming power to update the totals.
One presumes that the unit tries to compensate by adding an amount of energy based on elapsed time (I presume there is a clock) as well as last known power level. That would be an accurate compensation provided there is not a transition (off-to-on or on-to-off) occuring during the critical period while last-know power is used as a substitue for actual power.
At first glance, that would seem like a random error, since the probability of hitting off-to-on is same as hitting on-to-off, isn't it? No, actually not. An off-to-on transition can only occur when the heater was initially off, and an on-to-off transition can only occur when the heater was initially on. Considering the duty cycle and difference in power levels, the majority of pulses are sent (or at least the accumulator limits reached) during the on-state. So if we monitor for 1 day, we might have 1000 pulses sent from on-state and 100 pulses sent from off-state (just numbers for talking purposes). Since duration of off state and on-state are roughly the same, the probability of hitting a transition during that time interval is the same for both types.... let's say 10%. So 10% of the 1000 pulses while on experience an on-to-off transition during the critical time period and 10% of the 100 pulses while off experience an off-to-on transition during the critical time period. That is a lot more on-to-off type errors during a critical transition period than off-to-on type errors during a critical transition period.... ends up overcharging.
Or, maybe not
I admit that this is an abuse of the meters. But the intent of this exercise is to provoke bad behaviour - and I think we have just that. The customer's load also cycles, but with a lower rate and over months and years. Customer says that he thinks he has payed around 15 % too much, but data from parallel meter says that it could also be more.
I attach Excel sheets (sorry, I am in a hurry so I will use your code when not so pressed for time). I have reduced row heights so you can only see the first three - four rows, and after that only the rows where pulses are output.
Gunnar Englund
www.gke.org
Gunnar Englund
www.gke.org
At 2900 watts continuous, you would have 1 pulse/1.24 seconds.
It says 500 sec cycle on top, but below it says 2hz. I assume it is 500 millisecond cycle (?).
Than for 50% duty cycle, you have only .25 sec in each state.....so you have many heater on-off cycles between each pulse.
If I stick with the "theory" that I had suggested above, it would require that every single one of the pulse "triggers" (when integrator reaches the limit) occurred during on states (otherwise if pulse trigger occurred during offstate, we would have had a high watt-second reading).
For 50% duty cycle that is plausible. There is 2900/300 ~ 10x as much probability that each pulse trigger is reached during on state compared to off state.
For 20% duty cycle, it is not as much. 4x as much time in off state as on state. Only 2.5x as much probability that each pulse trigger is reached during on state compared to off state. I would have thought at least one of those 7 pulses during the 20% duty cycle would have shown a total which was at or above the 3600. So it does not seem very consistent with my theory from that standpoint. Given that there is some unknown delay in the neighborhood 1-2 seconds, there is no hope of going back to the data to figure out the condition when the trigger occurred.
Another thing to note: the average power is 1600 watts in 50% duty cycle and 820 watts in 20% duty cycle. If the trigger occurred during on state, the difference between "assumed" (under my theory) and average power would be 2900-1600 = 1300 watts at 50% duty cycle or 2900-820= 2080 watts at 20% duty cycle. Assuming the time for which the error occurs is the same, the ratio of errors for the 20 to 50 duty cycle should be 2080 to 1300... the actual ratio would be higher.
It would be interesting to see results if the cycle time were much slower such that you get let's say average of two or three pulse triggers in an on period and one pulse trigger in an off period. Maybe 3 seconds on, 12 seconds off. Then if timing of pulse relative to transition (or to state at time of pulse) is important, you should get some normal pulses (3600 watt seconds) and some pulses with lower watt seconds, and perhaps pulses with higher higher watts seconds. Focusing on the timing characteristics which are unique to the abnormal pulses and what preceded them might help define the mechanism better. Just a thought.
Of course that experiment probably means data collection over longer period of time which could become difficult to manage. And whether it's worth the effort depends in part on judgement of the likelihood of uncovering useful data. And I'm not sure if your goal is to recreate the behavior and that is all that is needed, or to how much additional effort would be warranted to understand the mechanism.
I can handle 60 second's worth of data. And there is no problem recreating a longer cycle - like the one we saw at the customer's place. Stand by! I am still confused. Want to make 100 % sure that this isn't a red herring.
Gunnar Englund
www.gke.org
I have checked the data acquisition and accumulation in my measuring device. It delivers very consistent data when I run without switching. All pulses are then worth between 3498 and 3505 Ws. Instantaneous power is in line with expectations and also with an electrodynamic wattmeter with class 0.2, so I feel confident about the measurements. What I think could be a problem is if the sampling interval isn't correctly specified. Then, the accumulated energy could be off with a few percent - which it perhaps is. Or, since the utility guys say that the meters can have errors up to 5 percent (which is hard to believe), it could also be that I am spot on - or close.
Gunnar Englund
www.gke.org
Yours
Bill
Bill
"Why not the best?"
Jimmy Carter
Sorry to such a bore. I have checked lots of combinations and this one is definitely sick. What the heck is going on?
Gunnar Englund
www.gke.org
I think stretching out the duration a little more may make the pattern clearer.
Actually, that is what we also saw on customer's site and what we have noticed in other recordings.
Do you know anything useful about sampling theory? Does this have anything with the retired railway man and the trains, that Bill mentioned in his 26 Feb 10 2:22 post, to do?
BTW, I am not so sure about the exact power levels in previous recordings. But, in this one, the levels are 180 W and 2700 W.
Gunnar Englund
www.gke.org
Gunnar Englund
www.gke.org
What is the new insight that it gives?
That strategy works in most circumstances but not when conduction angle is small. We will probably never know. The whole thing is now subject to discussions on a national level. Big money involved. And probably lawsuits.
Gunnar Englund
www.gke.org
No-doubt they got the bid to supply the bazillion meters because their POS was much cheaper than meters that actually work.
Nice work Gunnar.
Keith Cress
