thermal grooving
thermal grooving
thermal grooving
ASME secI PW-40.1 has a clear explanation of how a weld defect must be removed ---but if anyone could please explain to me what thermal grooving id sure appreciate it.
RE: thermal grooving
Yes, this means arc gouging or carbon arc gouging.
Adding a little to the post by metengr.  Every welder can use an Arc-Air rig or gouging rod, but only a few have the skill and fitness to do the job correctly. We have probably five out 26 welders that were allowed to use either process.  Do correctly cleanup is a breeze if not you will wear out several fitters and grinders.
Here is the website for Arc-Air products. Look at their videos and if you ever get a chance to watch a factory demonstration it will be worth your while.
http://www.thermadyne.com/arcair/
