Hydrocad Error 700
Hydrocad Error 700
I have a model with a single pond fed by two paved areas. The pond is prismatic with a bottom area of 6689 sf at an invert of -3.5 feet and a surface area of 8498 sf at an invert of -1.00 feet. By my hand calcs this should be a volume of 18,983 cubic feet. The runoff frm the two areas is 0.22 af and 0.205 af for a total of 18,513 cu ft.
When I try to see the hydrograph for the pond I get "Error 700 Unable to extend routing tables above -1.00 feet". Looking at Help indicates that the pond is filling beyond the -1.00 level even though the pond volume is greater than the total runoff even if there were no exfiltration, which there is.
I get the same error message even when I make bottom the invert 4.00 feet and move the top one up to 0.00.
I figure I must be entering something into the wrong box.
Any ideas?
Any ideas?
RE: Hydrocad Error 700
If you still have questions please post the file or send it to HydroCAD support.
Peter Smart
HydroCAD Software
www.hydrocad.net
Thanks for the quick response. I did that already but will try it again and take a closer look.
