AC compressor oil consumption
I have AC unit of 80 tons capacity with aworking compressor w-type (carrier) it has been retrofited to R-134a,using synthetic poloyol ester oil as a lubricant,I know that the oil may be transfered through the system as amist with the refrigerant. may concern is to know the actual oil level in the compressor.
I would like to know if there is a specific procedures to be sure that the oil that goes through the system is returned back to the compressor.
and also,
what is the indications for oil condensation at any place through the system?
Thanks.
and also,
Thanks.
RE: AC compressor oil consumption
As that happens you'll see the oil level fall in the compressor. When it stops falling, top the oil back up and watch it for another few hours. It should stay pretty level.
