solidedge st2
solidedge st2
solidedge st2
When i try to create a sketch, i can not change any dimentions at all (all my dimension is in blue color and got the under line when i tried to changed it). I think, something wrong with my setting. Can someboby please help me out with this one???
RE: solidedge st2
You don't say whether you are in sync or trad, but I believe it's the same scenario
It sounds like your dimensions are locked.
To change a dimension from locked to unlocked, click the lock symbol on the dimension value edit handle, which is displayed when you click to place the dimension.
Or click the lock symbol in the Value area of the smart dimension or edit dimension areas. Right hand side of screen under the ribbon bar.
RE: solidedge st2
It is Trad., i will try it.
Thanks a lot.
RE: solidedge st2
I think it sounds more like for some reason your dimensions are driven dimensions (blue) and cannot be changed (underlined) unless they are converted to driving dimensions.
RE: solidedge st2
Thank you very much
it is OK now.
