Wind exposure category in mountains
Hi Everyone,
Wind exposure categories per ASCE do not directly address mountains.  I am working on a residential project on a mountain with a slope of 42 degrees.  The mountain is wooded.
Surface roughness B: ...wooded areas...
Surface roughness D: ...unobstructed areas...
What would you use?
Thanks!
Eric McDonald, PE
McDonald Structural Engineering, PLLC
RE: Wind exposure category in mountains
You must use the more stringent requirement if it is an interpretive issue.  Check with the local building department....they might have some guidelines.
Thanks Ron - that is what I have been going with.
Eric McDonald, PE
When designing a house on a 42 degree mountain slope, I'd not lose sleep over using a more conservative wind load...
H&** - I am worried about the driveway or walkway down to the house..
You will probably find that this is a special wind region.
