Maximum torque can be transmitted in a Shrink Fit
At work we perform a hooping ring on a shaft. The ring and the axis are of steel. Outside diameter of ring = 580mm and inner diameter of the ring or outside diameter of shaft = 470mm. And the interference is 0.65 mm. How do you calculate maximum torque can be transmitted?
RE: Maximum torque can be transmitted in a Shrink Fit
Look at this post the answer is there:
thread404-266050: Estimating break-away force for an interference fit?
desertfox
or
http://www
These are usually simplifications of Lame's equation considering plastic deformation.
You must also consider the burst stresses and deformation consequences (ie if an internal (female) thread for a flange bolt is going to exist on an internal diameter of the shaft).
A lot of this is best done in FEA to confirm the calculator results.
Cheers
Greg Locock
