replacing dimension manually with letters
Can anybody share, how to replace dimension in 2d drafting manually. I want to replace a dimension with a word.
Thanks.
Cgelang
RE: replacing dimension manually with letters
That's correct...
You can only change the created dimensions though, you cannot do this with the parametric dimension.
Replace the D with the letter O, then type what you want to see.
Thank you so much to your reply. It's a great help.
Cheers,
cgelang
you may want to make a mapkey if you have bunches
