How to model this hole pattern on the outside circumference of a shaft
Attached are pictures of what I'm trying to do.
The round diameter where the small holes are is 1.5" O.D.
The diameter of the small holes is: .030"
The holes are spaced .040" apart.
I can't figure out how to model holes in this pattern on the outside circumference of this shaft.
any help would be greatly appreciated... maybe if you could include an actual solidworks model that would be easiest so I can see the features used, etc.
Thanks so much!
Thanks so much!
RE: How to model this hole pattern on the outside circumference of a shaft
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
Deepak Gupta
SW2009 SP4.1
SW2007 SP5.0
MathCAD 14.0
Create one hole, CD pattern it. This gives one half of the top row of holes.
Linear pattern, this gives one half of the all 3 rows.
Now mirror it.
~ BT
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
I was sure that worked before.
I thought, did and got exactly what you did. SW2009SP4.1
Rob Stupplebeen
Hopefully the pictures will come through. If not I will repost.
Rob Stupplebeen
Rob Stupplebeen
thanks so much! this forum is a great resource!!!
