which motor has high power/weight ratio?
I would like to know which of the following motors (brush permanent magnet DC motor, brushless DC motor and linear motor) have less size and weight at the same power (high power/weight)?
RE: which motor has high power/weight ratio?
For instance I have worked on linear motors that were about twenty miles long. They have since been extended several times. Over twenty miles of LIM rail weighs a lot! Divide by the number of propulsion coils in use and it still weighs a lot.
Bill
"Why not the best?"
Jimmy Carter
