Python Scripting to Automate Corrosion Details - Help Finding Examples
I have a CAE model, of a pressure vessel, that I have generated entirely within CAE (3D-solid model).  I also have a set of thickness data on a regular grid showing a local-thin-area.  I would like to automate the process of inputting the thickness information to generate this corroded model - using python.
I think that using the mdb.models['myModel'].parts['myPart']nodes.editNode approach would be the most computationally-efficient.  However, I cannot find in the Abaqus Scripting Reference Manual (v6.9) how I can:
1) Find the node closest to a specific coordinate
2) Return the coordinate of that node
I have the script to calculate how much to move the node, once I know which node it is, and where it is.
Does anyone have examples of how to do this?
Or is there an easier way of doing this?
RE: Python Scripting to Automate Corrosion Details - Help Finding Examples
lookup the examples that access the ODB (odbAccess in ref. manual). there is one that returns the node coords (or were they deformed coords, not sure -- it doesn't matter anyway). you will basically need to fetch all the node labels and coords and check, which one is the closest.
