Transmission loss of structural panels
Hai,
Is there any standards for carrying out(experimentally) the transmission loss of structural panels.
The concerns are
1) What should be the configuation of sound source?
2) How the panel should be prepared and what should be its
dimensions?(The panel is not having any surface treatment)
3) What about the environement around the panel(free field!!) and how the plate should be supported?
4) Where to place the sound source and microphones?
Is there any web-site regarding the above information?
Is there any formula for calculating the transmission loss of structural panel?
With Regards
logesh
The concerns are
With Regards
logesh
RE: Transmission loss of structural panels
There are smaller machines on the market - I have used an APAMAT myself, but it does not correlate very well with the TL suite.
For automotive work we used panels about 1m square, simply supported at the edge. Sealing of the edges is very important.
There are many equations for TL in the literature, depending on the approximate form of your panel, but really the behaviour is governed by the mass law, any subtle tuning effects are superimposed on that. The SAE is sure to have papers on that, but I don't know any reference numbers.
I know that standard reference texts for noise and vibration cover this, I suggest you look them up - Beranek being the obvious source.
Cheers
Greg Locock
The full book citation is:
Noise and Vibration Control Engineering: Principles and Applications
Editors
Beranek and Ver
1992 Second Ed
A list of acoutical standards go to:
http://www.industrialacoustics.com/RDMETH.htm
For a description of carrying out the laboratory test go to:
http://www.acoustics.auckland.ac.nz/ATS/ATS_test_list.html#Airborne%20Sound%20Insulation
An interesting subscription site is:
http://www.vibrationdata.com/tutorials.htm
Hope this helps
Bob B:-)
Michael
