Going between Mathcad and Excel
I was asked to set up a Mathcad sheet to analyze data taken from different people in the shop testing different heat exchangers. The Mathcad sheet is completely built and functioning properly. The problem is that no one else knows how to use Mathcad and therefore refuses to. Is there a way for me to have them plug data from testing into Excel and use Mathcad to calculate the desired values and read them back into Excel? Thanks
RE: Going between Mathcad and Excel
TTFN
http://www.ptc.com/community/free-downloads.htm
The only problem you might encounter with your application is with licensing. I think the end user needs to have Mathcad installed on their computer while using this plug-in. If this is not the case, please let us know - I could make use of a similar application.
Peter
TTFN
TTFN
