Pressure Drop in a Grooved pipe
The airflow inlet into a 1" grooved copper pipe is 270 cubic feet per minute. The pressure is 105 psi, at an inlet temperature of 30 F. The copper tube is 1 ft long and is twisted.
How do you calculate pressure drop through twisted tubes?
RE: Pressure Drop in a Grooved pipe
Hope it could help
I should've been more specific. The pipe is corrugated copper (little ridges on the surface).
http://www.pressure-drop.mobi/0105.html
