NX4 - Drafting - Format of Relationships expressions
In NX4 drafting, when you insert annotation, you can used an expression by using "relationships" tab.
This fonction open the "expression" window.
On the bottom of this window, you have the "format" of the expression, "0.2" by default, coresponding to the number of decimal before an after the "."
Is somebody know the way to change this default value, because I want to have "1,2" for having always a "0" before expression under 1 (ex: 0,92) and a "," instead of "." from a better visalisation on drawing and pdf exports.
See attached file form more details.
RE: NX4 - Drafting - Format of Relationships expressions
No, there's no way to change the default behavior of that setting, however, it sounds like a useful suggestion so I would contact GTAC and have them open an ER to that effect.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
I launch too a request on GTAC france...
And i go back to compare our results.
Response of the GTAC France :
He 'is unfortunately no option to change the default number of decimal places
When you add a phrase in a note drawing.
An enhancement request already exists on this subject, I've added to it.
Regards.
