Easy Definition of Node paths for XY plots
Does anyone know how to:
a) Define node paths for use in subsequent X-Y plots in a way which is more convenient than picking every node on the path (I have a lot of nodes on each of 4 paths)
b) Save the paths once defined so that when I come back into CAE next day the paths are still there.
I have figured out how to save the resulting X-Y plots in the .odb file but this doesn't help me today when I want to repeat the plots on the same paths but with a different output variable.
The four paths take me around an hour to produce each time
Gwolf.
Gwolf.
RE: Easy Definition of Node paths for XY plots
corus
