Relief valve pressure used to stress and support calculations.
Stress guys are doing their calculations in Caesar using the operation pressure for all the lines.
1. It is correct? Or have they to include a valve back pressure?
It is operations pressure good for all calculations?
2. When the support designer has to check the trunnion, at the relief valve discharge, what pressure will use? Operations? Design? include the force from back pressure shoot? They are using kellog method Excel datasheet for trunnions.
Thank you
Thank you
RE: Relief valve pressure used to stress and support calculations.
