Locating Solenoid Cartridge Valve >5 kpsi
I'm looking for a source to purchase solenoid cartridge valves with ratings greater than 5 kpsi. Any help or pointing in right direction is greatly appreciated.
RE: Locating Solenoid Cartridge Valve >5 kpsi
.. Have you looked into below sources?
Sauer Danfoss goes to 5080 with some solutions to 6000 for oil hydraulic. For air see Cunico.
You do not specify purpose, fluid (air or oil hydraulic (guessing hydraulic), application, on/off or diverting, flow requirement, operation time or other technical details.
More details could perhaps give a more helpful answer.
http://www.sauer-danfoss.com/stellent/groups/publications/documents/product_literature/11035457.pdf
http://www.cunicocorp.com/download/800series_1107.pdf
Depending where you're based, Sterling Hydraulics may be of some help too:
http://www.sterling-hydraulics.co.uk
Heather Smith
My interests: Alloy valves, duplex valves, super duplex valves, 6Moly valves, inconel valves, incoloy valves, alloy 20 valves and titanium valves.
