Explode-offset line problem
We use WF 2.0 and I was placing some offset lines in an exploded view.  I had positioned my parts where I wanted them and then tried to place the offset lines.  When I placed the offset lines they Pro-E positioned them as if the parts were in there "un-exploded" location.  In other words the offset lines showed up in the exploded view but not attached to the parts at their exploded location.  What's wrong with this?  Is there some setting that controls this?
SrG.
RE: Explode-offset line problem
Just a thought, did you save the explode state?
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
www.infotechpr.net
Yea. You probably forgot to save the exploded state after repositioning some parts. I do it all the time. It doesn't help that you save it in a different window than you move the parts in. cumbersome to say the least. Adding the offset lines is a pain anyway without this issue.
David
