Import iges text into Catia V5 model
I need to be able to import iges files into my part files. the iges files contain geometric data from an airfoil design package and text defining the parameters used to create the geometry. I think it would be ok if the text came into the drawing space as long as it all comes in at once.
RE: Import iges text into Catia V5 model
Ed,
   change the extension from .igs to .ig2  This will read your data into a CATDrawing file.
Derek
Catia is SO weird! Thank you, this may have to do.
