Rate of Change of Decreasing Pressure in Vessel (Help a EE!)
Do not need to get too detailed, but I need to know the rate of change of the pressure in a vessel(gas digester) caused by a compressor sucking the gas (methane) out. Starting pressures are 0-10 inches.
RE: Rate of Change of Decreasing Pressure in Vessel (Help a EE!)
Q = (V/t)ln(P1/P2)
Q is average volumetric pumping rate
V is volume of the system
t is time
P is absolute pressure
Use consistent units.
Good luck,
Latexman
