jobname.rst file error
As above, this error has been continuous problem for me and has stopped me from getting any results. I thought it may be due to files overwriting each other so I started my analysis again in a new directory with a new jobname and new title, when I solved the modal soltion, i got an error saying "split jobname.rst file", previously program was saying no .rst file.
Does anyone know what may be causing this?
I'v attached the exact process I went through to get my modal solution, I'd appreciate if someone could have a glance through my procedure and maybe see if something is causing the error.
