Biodiesel use in combustion turbine
Anyone have experience using Biodiesel as the primary fuel for Combustion turbines?
What issues did you experience?
Specifically:
-combustor/fuel nozzels
-filter clogging
-cold weather performance
-above ground storage tanks
Thank You
Specifically:
-filter clogging
Thank You
RE: Biodiesel use in combustion turbine
rmw
"Problems with B100 include material compatibility with seals,
gaskets, and other fuel system components, cold weather freezing, storage stability, and
NOx emissions exceeding CI engine certification levels. B100's technical problems (other
than NOx emissions) can be minimized by retrofitting fuel system components, adding fuel
system heaters, and using storage stability additives and biocides if necessary"
