Can you name this structural roof system?
We are doing some minor modifications to this hollow corrugated concrete structural system. The corrugations are used as ducts... so at the center of each of the corrugations, there is a penetration in the supporting concrete beam.
RE: Can you name this structural roof system?
Nice... it looks like a folded plate a bit...
Dik
The system spans 70 feet between beams.
Agree with dik...folded plate.
BA
Span is consistent with a folded plate... main rfg at top and bottom 'points' with adjacent plate providing lateral support (like a series of arches).  Matter of taking a look at the last panel to see how it is braced.
Dik
What does it look like from above?  Does the roof follow the same ridge/valley pattern as the ceiling?  Or is it flat roof, with a flat structural slab over the entire system?  I have seen both.
Page 29 of the Dec 2009 Concrete International pictures a precast system like this.  Prestressed, hollow box girders carrying mechanical services inside.
It appears to be this system.
