Steam reboilers
Steam reboilers
S!
I'm kind lost about the principles behind a thermosiphon steam reboiler. I'm mean: when it's necessaty to increase the heat duty, normally, in a steam flow/reboiler level cascade control strategy, the set point of the reboiler level is decreased. The resulting increase of heat duty is consequece of the an larger heat exchange surface, or is consequence of a bigger temperature difference between the steam's temperature (lower as consequence of the smaller pressure - steam expasion due to increase of "free" volume) and wall/boiling liquid's temperature, or is a sum of both effects?
RE: Steam reboilers
Another method, which is less common, is to put the control valve in the condensate outlet. This works by varying the back-up of condensate in the steam chest, thus effectively making the reboiler a variable-area device since the heat transfer coefficient from the liquid condensate is negligible compared with the HTC for the condensing steam.
Considering the classic heat transfer equation of
Q = U x A x Δt
in the first scenario you are varying Δt while in the second you are varying A. In both cases U is constant.
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
RE: Steam reboilers
Hum, I see.
Here we have a composition of the alternatives. The heat duty control loop uses a cascade control. The steam inlet (t/h) sets the set point of the level in the condensate drum. The level control manipulates the condensate's outlet valve.
What would be the main mechanism behind?
RE: Steam reboilers
If the condensate drum is below the reboiler then I cannot understand how it functions. If you could post a sketch it would help.
Katmar Software
RE: Steam reboilers
The drum is leveled with reboilers.
Thank you.
Cheers.
