Bioogical contamination in purified water system
Dear Sir/Mme
I'm a pharmaceutical engineer and know I'm facing a big contamination in the purified water outlets and main curves If some one have a solution or can help me that will be very awesome
Standing ready to receive your comments
RE: Bioogical contamination in purified water system
I have done sanitization more time even by Cl but it takes few days to come backIt made me mad
Mark Hutton
Plymouth Tube
I would recomend a heat sanitisation, I suspect that you have a bio film. The issue here is that wiht chemical sanitisation only the top layer is killed. it then comes away and a new fresh live layer is revealed. a good heat soak will penetrate the colonies. Good luck.
Mark Hutton
