high resistance in motor feed cable
I have discovered a feed cable (4 core, 3 phase and neutral)that supplies a panel from which several motors are fed from, having a resistance on each core of average 35 ohms. Normally a high resistance would reduce the current, but would it increase it to provide the motors with sufficient power?
RE: high resistance in motor feed cable
Gunnar Englund
www.gke.org
With this area, the cables probably carry around 100 A. That would produce a voltage drop equal to 350 volts in a 35 ohm cable. Are you really sure that your measurements are OK?
Gunnar Englund
www.gke.org
Have you tried with a different meter? How are you checking the resistance? Are cables disconnected at both ends?
Rafiq Bulsara
http://www.srengineersct.com
Muthu
www.edison.co.in
To take Gunnar's example one step further:
100 Amps x 350 Volts drop = 35000Watts or 35 kW of waste heat. The point is, that much resistance (35 Ohms) in a feeder will generate enough heat to be be noticeable and will lead to rapid complete failure.
Metering issues are much more likely.
Bill
"Why not the best?"
Jimmy Carter
Bill
"Why not the best?"
Jimmy Carter
Gunnar Englund
www.gke.org
