Water draw-off in Products storage tanks
I am seeking for an advice for applicable and advanced method to draw-off water out of refined products storage tanks (Diesel, Gasoline and Kerosene). The practice we do to draw-off water is to gauge the tank to determine the level of water presence, then open the drain line manually to draw-off almost 80% of measured quantify. This practice is not accurate and subjected to human error in detraining cut-off point between oily water and pure product.
I appreciate if anyone can present more advanced method better than what we are using, thanks.
RE: Water draw-off in Products storage tanks
This is the typical setup at tankfarms that deal with hydrocarbon cuts, excluding the obvious like residuum and really light ends such as certain LPG's and naphthas.
Will Chevron Corp.
http:/
